Tourqe converter bolt help
I've been away from the Land rovers for a little while. My son and I decided to go to junkyard and pull a trans for the D1 so we can get it going again and we are laying under this discovery one on bolting the trans and I can't figure out how to get the torque converter bolts out the rest of the way
It took off the inspection cover. I was able to get in there and break them loose spin it break the next one loose spin. It break the next one loose. But how do I get them out all the way the oil pans in the way and I don't see an access hole
So answer is He's a 13 mm box wrench to get the torque converter bolt hole lined up between the block and the oil pan on the side where the starter is. Use a shallow socket and a while a swivel or universal and extension and that's how you get it out
