Towing question
Put the truck in neutral, make sure the parking brake is off and you can pull it forever.
Now, mind you the disco is to heavy for a Uhaul toe dolly, so if your planning on renting one you will have to lie... (tell them your towing a VW or something) Personally, I would go with the tow bar.
Buying a tow bar is actually cheaper than renting the dolly in a lot of cases at around 120 bucks new...
So for the front wheels off the ground remove the rear shaft.
Mark the drive flang at the trans case and the axels with lines so you can refit to the original position when your done.
Also, make sure you turn your key to release the steering wheel lock... don't forget to do this or you will break something the first corner you take. (most likely the steering linkage. )
