Trailing Arm Bushes Don't Fit (NTC9027)
Old Nov 27, 2011 | 03:59 PM
AuZZZie's Avatar
Default Trailing Arm Bushes Don't Fit (NTC9027)
Nothing is ever simple on this bloody truck.
Installing my Rovertracks rear radius arms. Got everything off no problem. Go to install the new arms and the frigging OEM arm to chassis bushing don't fit.
I'm using NTC9027. I can't for the life of me get the ****ing thing onto the trailing arm. The old ones slide on and off no worries but I'm guessing cause they are worn.
I've read 100 guides/posts online and not one person has mentioned needing a press to get them on the arm. Is that the case?
Old Nov 27, 2011 | 05:11 PM
antichrist's Avatar
Have you measured the OE and Rovertracks arms to see if there is a difference in diameter?
If not then you maybe have a defective bush. If the Rovertracks is actually larger, I'd call them.
Old Nov 27, 2011 | 05:30 PM
AuZZZie's Avatar
Here's the thing..
I have two NTC9027 bushings. Both have the same problem.
The new bushings also don't fit the old stock arms. Same ridiciliously snug fit.
I'm so confused why the hell they won't just fit.
Old Nov 29, 2011 | 06:19 PM
Jake1996D1's Avatar
Originally Posted by AuZZZie
Here's the thing..
How off are they? try sticking them in the freezer over night and then tap them in with a socket...
Drillbit
Apr 4, 2014 02:10 PM
calebbo
Oct 12, 2011 09:54 PM
Disco Mike
May 4, 2011 07:08 PM
kjj0506
Sep 22, 2007 06:34 PM
glynn
Apr 20, 2005 09:26 PM
