trans filter change
Old Nov 16, 2010 | 07:51 PM
thehun's Avatar
Default trans filter change
is there any way to get the pan out without dropping the cross member?
Old Nov 16, 2010 | 08:05 PM
thehun's Avatar
also...can the cross member be taken out without removal of the y-pipe?
Old Nov 16, 2010 | 08:19 PM
Yes, no, kinda.
You must remove the cross member but you only need to loosen the y-pipe.
Old Nov 16, 2010 | 08:30 PM
kenk's Avatar
That's why I paid $200 to have it done.
Old Nov 16, 2010 | 08:53 PM
Long Haul's Avatar
Its not an easy job by any means. You can loosen the Y pipe enough to move the crossmember out of the way. It makes it easier if you have a porta-power to spread the frame rails to move the crossmember (its a tight fit)
Old Nov 16, 2010 | 08:59 PM
DiscoSux's Avatar
Porta power? F-me! You truck drivers over-do everything.
Beware Long Haul - Disco on the road in E-town...
http://picasaweb.google.com/lh/photo...eat=directlink
Old Nov 16, 2010 | 09:04 PM
thehun's Avatar
This is probably the only thing I hate about the D1 Disco's is the darn crossmember crap removal for a transmission filter
DiscoSux's Avatar
Get that TF kit yet? I got half of mine.
Old Nov 16, 2010 | 09:22 PM
thehun's Avatar
Thursday is the day..ups shows 93lbs ...sunday is the install day...getting new front brakes...rubberized shock tower ring...hopefully a good day
Old Nov 16, 2010 | 09:26 PM
DiscoSux's Avatar
Rock on -report back on the install Hun boy. ;-)
