Transfer case cover nut size
Old Nov 7, 2020 | 11:35 AM
disco96sd's Avatar
Default Transfer case cover nut size
I did a search and didn't find my answer
going to change out the transmission speed sensor and change the T-case gear oil - figured I would put on a new cover gasket and I understand should use new nuts
anyone know the correct nuts and gasket parts - best supplier ?
Thanks as always
Old Nov 7, 2020 | 12:44 PM
robertf's Avatar
It uses bolts, and if yours is a 96 it likely has rtv instead of a gasket so its probably not leaking from the cover
Old Nov 7, 2020 | 01:18 PM
disco96sd's Avatar
thanks
ChawtonDiscoII
Dec 18, 2017 03:33 PM
archaeology_student
Aug 2, 2014 09:43 AM
Fallstaff
Apr 11, 2013 11:11 PM
04DiscoverySE
Oct 17, 2012 10:41 AM
willrok13
Aug 2, 2011 03:00 AM
