Leaky Transfer Case
Old Jul 16, 2012 | 05:09 AM
04DiscoverySE's Avatar
8th Gear
Default Leaky Transfer Case
Just changed the motor oil in my '04 Discovery SE(46k mi) and noticed the transfer case cover was saturated in oil. Never noticed it dripping on my driveway, a few bolts had droplets of oil on them but that's about it. I did a search and was wondering to replace the gasket or just switch to a heavier oil(140wt). Truck is in Macedonia so parts are extremely difficult to find. And the nearest Land Rover Dealer is 3hrs away.
Anyway to check the transfer case oil level? Or just go ahead and change it? Any specail tools/pumps required?
Old Jul 16, 2012 | 05:18 AM
There is a 1/2 inch square drive fitting that you back out, similar to a differential plug. That is the fill hole.
The drain fitting is a more delicate plug with a magnetic tip.
The inspection plate can be removed cleaned off, and resealed with RTV. I don't think there is a special gasket for it. Many use 85W140.
See https://landroverforums.com/forum/sh...ad.php?t=27159
You can use a small pump made to fit in oil jugs, or buy a cheap garden pump sprayer and take off the nozzle.
BTW, go ahead and do the two differentials also. 85W140 also.
Old Jul 16, 2012 | 09:21 AM
Where exactly is the leak, are you referring to the inspection plate on the bottom of the t/case, if so, remove it, clean off the junk and reseal it and you will be fine.
How long has it been since your serviced, as in a Major service, that truck? If it has been awhile, then do both the diffs and t/case with an 85/150, takes 7 quarts in total.
Old Jul 16, 2012 | 11:25 AM
8th Gear
Yes the oil looks like its just coming from the T/case inspection plate.
Do I need any drain/fill washers for the T/Case & Diffs?
Old Oct 16, 2012 | 05:23 PM
Joshman's Avatar
Do you guys have a recommendation on the sealant/gasket goo used on this job? The RAVE repair manual also calls for a certain type of stuff to put on the screws, should I just use loc-tite? I have drips forming on like 5 of the bolt heads, so this will be the job for this weekend. Thanks.
Old Oct 16, 2012 | 08:57 PM
discoIIchick's Avatar
5th Gear
I used black rtv for my inspection plate that was leaking. Worked like a champchamp
Old Oct 17, 2012 | 12:04 AM
Rover_Hokie's Avatar
Locate the T/C fill plug and get it loose BEFORE you drain the T/C!! Releasing the parking brake loosens the tension on the large brake cable that is in the way near the fill plug, so you can move it a bit to get a better angle to access the fill plug. Some people use a wobble or universal swivel socket attachment. Use the 1/2" square drive end of the ratchet with no socket as noted earlier. Depending on if it has been out before and the road conditions it may have seen in its life; it can be tough to remove.
Old Oct 17, 2012 | 10:41 AM
drowssap's Avatar
i used 1/2 inch drive rachet, a 12 inch extention & a 1/2 inch universal joint on the end, worked well. The 1/2 drive of the universal fits the plug and the extention allows you to go in over the top of the case and drive shaft from the rear.
FlyingZebra34
Apr 18, 2014 02:00 PM
weeeeeeeeeeee
Jan 7, 2007 05:36 PM
dillhole
Nov 12, 2006 03:35 PM
Benhamtroll
Jun 21, 2005 09:41 PM
DIMISA1977
Apr 20, 2005 09:33 PM
