Transfer case worries
Old Jul 29, 2014 | 12:50 PM
EricTyrrell's Avatar
My tcase doesn't whine except for in low range under load going "fast".
The drivelines in these do have some normal slop that worries people.
If it pops out of gear and there's nothing wrong with the shift machanism, then something is definitely wrong.
Old Jul 29, 2014 | 01:27 PM
Shiftonthefly1's Avatar
Originally Posted by Randall in NC
I had a vibration on my driveline so I decided to replace my U-Joints last week. When I went to remove the rear drive shaft, I discovered that two of the four bolts mounted on the transfer case flange were stripped and loose. This was the source of the vibration. If you remove the shafts to replace the U-Joints, I would replaced all of the 3/8"-24 Nuts and bolts. I used Grade 8 bolts and nuts, the nuts were the locking type.
A helpful tip, chock the wheels, remove the driveshaft on the axel sides first, and place the transmission in neutral to rotate and remove the axel bolts on the transfer case sides. If you remove the tcase flanges to replace the 3/8-24 bolts, a 30mm socket is needed and you may wish to replace the felt sealing washers on each end. A small amount of oil will leak out of the tcase once the flanges are removed so be prepared to catch the oil and refill during reassembly.
That's good info thank you. I replaced the bolts in my front shaft at both ends because mine was missing. I also used grade 8 from Ace Hardware. I had to remove the front flange and didn't notice anything odd on that end. I will look into the rear flange now too.
what type of ujoints did you use?
Old Jul 30, 2014 | 10:36 AM
Randall in NC's Avatar
I used the Advance Auto PDQ (Neapco)1005 that was suggested in the below linked post. The problem is that Advance is no longer stocking these U-Joints. I purchased the last ones stocked locally and the warehouse was empty per my local store. You may have to search for the Neapco brand and possibly pay the $25/joint vs. the $12/joint...
https://landroverforums.com/forum/ge...rebuild-29302/
Old Jul 30, 2014 | 01:37 PM
TOM R's Avatar
Amazon, AC delco
Amazon Amazon
Old Jul 30, 2014 | 06:02 PM
These are pics of my angles. None seem to excessive to me. Is this normal for a 2" lift?
Old Jul 30, 2014 | 07:52 PM
MM3846's Avatar
Old Jul 31, 2014 | 12:36 AM
Gimebakmybulits's Avatar
Is this normal?
Heck no it's not normal, there is no oil anywhere in those pic's!
Old Jul 31, 2014 | 08:35 AM
TOM R's Avatar
None of your u joints look greased, there should be grease everywhere, I am serious
Also lose the sway bars the ride will be better, especially before you hit the front drive shaft during suspension flex
Old Jul 31, 2014 | 08:43 AM
Yea I've been trying to fill them w grease a few times. I can only get one or two caps to fill up. That's why I want to change them regardless of this vibration.
The front sway bar is disconnected. It's just bungee 'd up to the frame.
Old Jul 31, 2014 | 08:47 AM
Haha. Yea that was a long road. I'm still chasing potential leaks I guess it never ends.
