Transfercase Shifter
Forgive me if I'm using the incorrect terminology, but I'm I Jeep guy and that's what it is for us.
My 96 has probably never been off road and may have never been shifted out of what is basically 4H. The **** is in the right most rear position. It will kind of give alittle when I try to push it forward, but I don't want to force it. It is by no means as easy as the youtube video in the sticky makes it out to be.
Any thoughts or suggestions on freeing it up? Does the console have to come out? Do I have to go up under it and access the linkage? If I pull the console, will I be able to gain access to the linkage?
Does anyone think a 5 MPH coast in neutral and trying to actuate it will do any good?
Was yours all crudded up in the little box where the nylon ball joint sits?
Any chance this is just stuck from lack of use and I could disconnect the linkages and try to work them? There's some give, but I don't want to force and break anything.
bigdrew4u
04-19-2008 04:41 PM
Roverboy3766
01-14-2008 09:30 PM
shawn
12-21-2007 11:53 AM
