rebuilding a transfercase?
Old Jan 8, 2008 | 05:34 PM
Roverboy3766's Avatar
Default rebuilding a transfercase?
is it alot of trouble and difficulty to rebuild the transfer case. someone told me when you take it about and rebuild you have take take alot of time a align alot gears in it. can it be done yourself or do you have to take it to a mechanic? its for a 96 Range Rover 4.0 se
Old Jan 9, 2008 | 12:32 PM
raid13's Avatar
Default RE: rebuilding a transfercase?
someone that has rebuits borgwarner transferboxes would have no
problem, but if you have never see the inside of a transferbox then i
would stay out.
if you want i have a body electrial control module (becm) used part number
YWC112210 that need to be unlock and programed to your VIN
its used and asking 100 dollars (because the core charge is 100 dollars)
Old Jan 9, 2008 | 02:26 PM
ajh's Avatar
ajh
Swap on an LT230 with CDL if you're doing offroading and you won't have future rebuild issues. (well most likely) Never liked the idea of having a viscous clutch and chain in the middle of the drivetrain.
Old Jan 9, 2008 | 05:46 PM
raid13's Avatar
ORIGINAL: ajh
WHAT? the front and rear diff's are on the other side on a range rover hows he going to do that?
Old Jan 13, 2008 | 11:27 PM
mrmack's Avatar
What is the problem with yours...symptoms...... I have replaced the chain in mines .... but the gears where fine so didn't see a need to relace 'em
Old Jan 14, 2008 | 10:19 AM
when i take off from a stop sign or driveway, i can hear the transfercase go bang bang bang. it wont do it as much if you take it easy driving off. but it is really bad. and really noticable that something is not right. i have changed the tranny fluid and i have looked for metal chippings in the fluid but i didnt see any. but i need to find a transfer case for less than $1000 but i dont know where. roverlandparts.com wants over $1500. I COULD ONLY IMAGINE WHAT LAND ROVER WANTS.
Old Jan 14, 2008 | 12:09 PM
What year is your truck?
Old Jan 14, 2008 | 09:30 PM
its a 1996 range rover 4.0 se
b18cx
Sep 24, 2008 09:51 PM
bigdrew4u
Apr 19, 2008 04:41 PM
shawn
Dec 21, 2007 11:53 AM
shawn
Oct 4, 2007 09:10 PM
ajh
Sep 17, 2006 02:36 AM
