trouble starting.
My truck won't start. Lent it to a buddy last night, the alarm was armed, he unlocked it with the key and not the fob (shouldn't be an issue) and tried to start it but it won't turn over. When you crank it you get power and one click. Nothing else. The alarm dashlight also freaks out, blinking really fast. I replaced the starter in Nov so I'm hopeful its not the starter. Went out this morning cleaned my terminals thoroughly. Cleaned the ground point to the frame and it still won't start. Tried jumping it, same story. Power, and one click. I haven't had time to check the starter solenoid ground but I'm about out of ideas and of course my landrover dealer service dept isn't open on Saturday. You guys have any thoughts? I need this truck to work. Thanks.
i tried the lock unlock method 3 times with the fob from the outside, no luck. Way more than three times from the outside, no luck. Tried it locking/unlocking via the key in the door, no luck. Tried turning it to accessory and leaving it for 30 seconds then turning off again and starting, no luck. Any other ideas? I'm 95% sure its the alarm, the click when i turn it over really sounds like an alarm kill on the starter.
I need help. thanks guys
tried the inertia switch, no luck. Tried the ignition in position #2 lock/unlock but it doesnt work (fob wont lock or unlock) in position two, tried it in position #1 and the three unlocks didnt work. Now, i'm starting to think maybe its not an alarm issue, maybe its the starter solenoid. I replaced the starter 12/09 but it was an advanced auto parts refurb unit. It has a lifetime warranty so im thinking i may have to pull the starter tomorrow and take it to them to bench test it. My area landrover dealer wont be open till monday for service inquiries so i guess i'll just try this.
Sound like the next plan of action?
