truck dying with new alternator
Old Jun 8, 2017 | 09:32 PM
jastutte's Avatar
Default truck dying with new alternator
backstory: 1996 NAS Discovery. son drives it. it's still in my name.
the tachometer started going crazy and the battery light came on. i tested the battery and it tested fine. so, figured it needed an alternator. ordered a used part from a reputable vendor and installed it. same issue. i will be pulling the alternator tomorrow to get it bench tested. if the alternator tests good what else should i check?
thanks,
Old Jun 8, 2017 | 09:57 PM
XCELLER8's Avatar
it's probably the alternator (again) my guess is that the used one wasn't good either...the tach is driven by a one wire feed off of the back of the alternator....just to be sure ....check that the terminals are clean and tight
Old Jun 9, 2017 | 01:29 AM
Icannap1's Avatar
Check the fuse under the hood 100 amp fuse located in the engine compartment fuse box passenger side black rectangular box near the battery and the overflow reservoir, you will need to use a volt meter to test that there is power on both sides of the fuse terminals. the plastic cover pulls up once cover is opened you will see screws that attach the fuse to the terminals.
Old Jun 10, 2017 | 03:29 PM
DiscoCam's Avatar
Literally had the same issue the other day. Ended up being a bad MAF sensor. Really strange but I replaced it with a used one and it solved the problem. Had autozone test my alternator and it was fine.
Old Jun 12, 2017 | 09:01 AM
jastutte's Avatar
put in a new alternator from O'Reilly's on Friday morning. truck is still running fine.
thanks to all that responded.
stevee
Apr 9, 2019 03:53 PM
mx468
Jun 25, 2015 03:56 PM
JumPeR04
Dec 17, 2009 07:57 PM
sarahgibbons5
Jun 14, 2009 11:36 AM
mgabriel
Dec 11, 2008 11:53 PM
