Turbo on Disco 1 V8 Petrol
Old May 30, 2017 | 06:55 PM
uoaou's Avatar
7th Gear
Originally Posted by xathor
If you want to run low boost without any ECU tuning, you can do a blow through MAF and a rising rate fuel pressure regulator.... For safety sake I'd probably add a water/meth kit as the ECU is going to try to lean out the mixture unless you're flooring it. The proper way would to be use an aftermarket ECU.
In my experience though, adding turbo's to vehicles that didn't come with them from the factory is a game left for those that really know what they are doing and are willing to deal with blown headgaskets and cracked ringlands.
Source: blown many headgaskets and cracked countless ringlands
Sounds High Risk / Low Reward to me. I don't have the practical knowledge to try something that will potentially cause more problems and has questionable benefits.
Thanks for all the replies. I'll give it a miss!
Old Jun 2, 2017 | 11:22 PM
ROB99DISCOSD's Avatar
You couldn't pay me to even consider a turbo on these engines. No way.
Old Jun 3, 2017 | 09:29 PM
DiscoCam's Avatar
Don't put any kind of force induction on a rover V8. They already struggle with reliability as a naturally aspirated engine.
If you still have your heart set on a turbo engine, maybe you could swap in a 300Tdi or like a 2JZ or something. Probably expensive to do so, but if you want to do that then go ahead. Best option for a turbo.
Old Jun 5, 2017 | 08:15 PM
whiskeynipple0088's Avatar
na.... swap a chevy LS in with twin turbos
Old Jun 6, 2017 | 01:40 PM
DiscoCam's Avatar
Personally, If I were to do an engine swap on my disco, I wouldn't want to mess with turbos. I would get a toyota 3UR-FE 5.7L with a TRD supercharger.
Fast and reliable.
viper205
Jun 17, 2008 07:44 PM
Petel
Dec 8, 2007 06:30 AM
strongbow
Jun 2, 2006 07:06 AM
gazabroad
Freelander
Jan 3, 2006 07:32 PM
Quophi
Aug 2, 2005 03:28 AM
