Turn signal lights flash when doors lock and unlock.
Old Jun 23, 2014 | 09:07 AM
Sam95disco's Avatar
Default Turn signal lights flash when doors lock and unlock.
Ever since I've had the truck the lights blinked when I'd lock and unlock the doors. Now they don't, the signals do work though. Is there some "key turning trick" to get them to blink again?
Thanks.
Old Jun 25, 2014 | 07:31 AM
Sam95disco's Avatar
Left, right, up, down, A,B,A,B, Start?
Old Jun 26, 2014 | 02:25 AM
roach131313's Avatar
Check your fuses under the hood near the battery. The horn and alarm are on the same fuse and when blown it will prevent the blinkers from flashing with the key fob. Your horn should be out too until you replace the fuse.
Old Jun 26, 2014 | 09:12 AM
MonteroMan's Avatar
Sam,
I have a similar problem.
What do you mean by this: Ever since I've had the truck the lights blinked when I'd lock and unlock the "Now they don't, the signals do work though". Are you referring to the green return lights on the instrument cluster?
Set off your alarm and listen to the relay operating the flashing of the hazard lights; you should hear the clicking. Then press the Hazard switch and listen to hear the seperate relay which is in its own circuit.
Check which relay causes the hazard lights to flash. Should be in sinchronisation to the alarm relay. If they do not you have a basis to start working from
Old Jun 26, 2014 | 05:51 PM
Sam95disco's Avatar
Horn works, alarm works. I don't have a key fob. The hazards flash, all turn signals work.
honda50r
May 19, 2020 06:51 AM
wynhd
Aug 28, 2012 11:33 PM
wheelgarage
May 23, 2012 07:43 PM
richierichrover
May 27, 2009 09:42 PM
russcan
Sep 14, 2008 10:45 AM
