Turn Signal Switch Woes
Old Jun 3, 2022 | 07:21 PM
DiscoNewbe's Avatar
Default Turn Signal Switch Woes
Hey Everyone, So, within the last year I’ve gone through two turn signal switches.
I just bought a third one from Atlantic British, it states that it’s Lucas and built in Great Britain, but on the box there is a typo where one of the letters was in Chinese so who knows. This time the issue was my turn signal was starting to not work when I would attempt to use it to turn. Last time, my headlights had stopped working except for my brights.
Also, I noticed that when the switches are starting to fail the turn signal clicks as I turn the wheel to finish my turn (with the switched engaged in either direction)
Is anyone else having this issue? Any ideas or advice?
Old Jun 5, 2022 | 01:07 AM
jvarnadoe's Avatar
I replaced my original with a Eurospare from RMEuropen in Littleton,CO around 1.5 years ago and have had no issues. Since you're in Denver, you can pick up from them and avoid shipping.
https://www.rmeuropean.com/Make/Land...bcatID=1724890
Old Jun 5, 2022 | 12:49 PM
ononomos's Avatar
When your original switch went bad, did you try spraying some rubbing alcohol in to the cap and twisting it. That worked for me, for a bit, and then I bought another used OEM one off ebay, easy as that.
Old Jun 5, 2022 | 02:50 PM
DiscoNewbe's Avatar
Thanks for that website, I appreciate the source
Old Jun 5, 2022 | 02:51 PM
DiscoNewbe's Avatar
No, I figured my original was probably pretty old so I was trying to get a new one that I figured would last forever
bode61
Nov 25, 2018 08:08 AM
alpinacsi
Feb 7, 2018 08:45 PM
TheyseemeRovin'
Mar 11, 2012 06:05 PM
99LRDisc
May 21, 2009 08:52 PM
NLAT
Mar 16, 2008 04:44 PM
