Turn signals flash constanly/ 1994 discovery
Old Feb 27, 2023 | 05:12 PM
Superx03's Avatar
6th Gear
Unhappy Turn signals flash constanly/ 1994 discovery
hello i have a 1994 land rover discovery and I recently ran over a pot hole going 30 and now all of a sudden my turn signals flash constantly. The hazard switch is off and when I use the turn indictor both turn signals still flash, then after the car is off they still both flash. i have disconnected the battery and the turn off but when reconnecting the battery the turn back on, the same with removing the turn signal/ brake lights fuse. is there a switch that got stuck or relay? my manual only tells me about fuses and no relays
Old Feb 27, 2023 | 08:53 PM
JohnZo's Avatar
Maybe pry out the hazard switch and disconnect wires?
Old Feb 28, 2023 | 02:00 AM
Superx03's Avatar
6th Gear
*update* I've found that the Relay Alarm System was constantly going even though the security system was not engaged, I was able to start and move the car and still use all lights without this relay. I'm going to replace the relay and see if this fix the problem
Old Mar 8, 2023 | 07:34 PM
tonybologna's Avatar
4wd High
I believe there is an alarm ecu/box under the glovebox that has a sensor that detects crashes. When triggered, itll flash your hazards, unlock your doors, and cut fuel because it thinks you were in an accident.
defenderobx
Defender
Sep 27, 2022 08:31 AM
defenderobx
Aug 5, 2022 01:55 PM
DiscoNewbe
Jun 5, 2022 02:51 PM
mylesman12
Jun 11, 2013 11:20 AM
NLAT
Mar 16, 2008 04:44 PM
