Twitchy A/C and Recirc button activation
Old Aug 24, 2010 | 03:41 PM
ColoDisco's Avatar
Default Twitchy A/C and Recirc button activation
I have had this problem for a while and did a search, nothing came up.
When I turn on the recirc button it does not activate. If I tap on it long enough while activated eventually it works. Anyone ever taken one of these apart and cleaned the contacts? Possible?
Old Aug 24, 2010 | 04:58 PM
Anything is possible if you have enough time and money.
Try it and let us know what happens.
Old Aug 24, 2010 | 05:23 PM
ColoDisco's Avatar
I love your philisophical/f*** it advice spike!
I will do so and report back!
Old Aug 24, 2010 | 07:31 PM
ngarover's Avatar
I had the same issue last week. So I pulled out the switch. Took it completely apart, cleaned it ruffed up the contacts a little put it all back together and it works great now.
So your answer would be yes.
As far as a step by step... go slow, use common sense and you'll figure it out. If I can do it, anyone can. BTW, this goes for all the other switches also. The same day I took apart and cleaned 2 or the window switches, and the drivers side seat controls. Warning, there are a bunch of little rockers/ball bearing and springs in these... pain, but doable.
Old Aug 25, 2010 | 11:13 AM
ColoDisco's Avatar
I have done this on my 944 but was not sure if these were solid state.
I love simple copper/brass internals to switches. Thanks for the response.
Plan on tackling this today.
Old Aug 25, 2010 | 05:55 PM
If it was a DII you would have to buy a new HVAC control panel, but you have a DI.
So this is yet another reason a DI is better than a DII.
Old Aug 25, 2010 | 06:29 PM
ColoDisco's Avatar
Done and working!
So.. the part that fails is the little copper strip which has bent tabs to contact the lower main copper tabs which connect to the actual wires. I cleaned up the surfaces, removed the upper copper strip and added a little more bend to them and reassembled. Works like a charm!
Old Aug 25, 2010 | 06:45 PM
Sweet!!
Old Aug 25, 2010 | 07:48 PM
ngarover's Avatar
Originally Posted by ColoDisco
Done and working!
Told ya!
Good job... feels a lot better than buying a new switch eh?
Old Aug 26, 2010 | 12:11 PM
ColoDisco's Avatar
Oh yes!! Love the older technology. Hence why I bought a 88 944.
LRadventure
Jan 5, 2014 10:31 PM
softcar2008
Dec 15, 2008 03:17 PM
softcar2008
Dec 14, 2008 02:35 PM
jmt
Dec 28, 2007 03:22 PM
