U-Joint Zerk fitting - how do you reach them?
Old May 18, 2020 | 07:40 PM
archaeology_student's Avatar
Default U-Joint Zerk fitting - how do you reach them?
Is there a trick to getting the grease gun to reach the zerk fittings in the u-joints?
It seems as though the tip of the grease gun is a hair too wide to allow a proper connection
thanks!
Old May 19, 2020 | 06:02 AM
Toran's Avatar
Are you using a grease gun with a flexible hose?
Post an image
Old May 19, 2020 | 09:17 AM
Post an image
Yes, it is a basic grease gun with a flexible hose. The yokes of the u-joints (upgraded to hardy spicer) do not seem to have the clearance to allow for a secure connection.
I was thinking of finding longer zerk fittings to allow for greasing and then putting back the original zerk fittings.
Old May 20, 2020 | 08:06 AM
scsand's Avatar
A lot of times those are a tight fit. I use a narrow needle tip on my grease gun.. much easier to get into tight places and works great.. below is link to example one.
https://www.amazon.com/LockNLube-Narrow-Needle-Dispenser/dp/B0779FK9CZ/ref=sr_1_16?dchild=1&keywords=grease+gun+tips&qid=1589979836&sr=8-16 https://www.amazon.com/LockNLube-Narrow-Needle-Dispenser/dp/B0779FK9CZ/ref=sr_1_16?dchild=1&keywords=grease+gun+tips&qid=1589979836&sr=8-16
Old May 20, 2020 | 11:35 AM
Banzai Jimmy's Avatar
How hard did you push? It may take a very firm push to get it in there and seated properly. If you have concerns about damaging the grease gun fitting, I'd recommend setting them aside as I doubt you'll deform, etc. the fitting.
Old May 21, 2020 | 04:23 AM
JUKE179r's Avatar
I know on my Disco 2 the angle of the U-joint can make it a pain to fully lock onto the zerk fittings. That lube needle attachment helps.
Old May 21, 2020 | 07:34 AM
scsand's Avatar
Very easy to use.. I've used it on D1's and D2's drive shafts... don't have to push hard at all. It's all I use now.
Old May 22, 2020 | 10:58 AM
Yes, the needle made it super easy!
Now if only such a tool existed for reaching the manual transmission’s reverse light switch.... that is not fun lol
back9sunday
Jun 9, 2016 01:52 PM
the420star
Aug 6, 2015 12:08 AM
sorbet35
Apr 22, 2012 08:24 PM
chad420
Jul 5, 2009 10:27 AM
Darover
Apr 3, 2008 11:45 AM
