Um, grumbling from below
Old Oct 14, 2011 | 02:12 PM
slanginsanjuan's Avatar
Default Um, grumbling from below
96D1 104K currently rebuilding
I'm hearing a light grumbling sound from under the truck. I'm guessing that the propshaft is working its way loose. Maybe related to 2" lift and change of usage. I think its an original so...
My mechanic is real sick so I am going to try and work through this a little myself - hopefully with a little help.
I'll post some facts and pics shortly.
Old Oct 14, 2011 | 02:19 PM
EricTyrrell's Avatar
For the two days I drove mine, a few times I noticed a similar sounding and clearly audible grumble from below the transfer case shifter area. Never figured out what it was. Luckily mine doesn't have rotoflex.
Old Oct 14, 2011 | 02:25 PM
Dosen't have an engine either... back to work!
And for the special gringo rate in PR, the D1 tech sticky has a propshaft rebuild write up with pictures. No charge!
Old Oct 14, 2011 | 02:32 PM
Chris-bob's Avatar
Maybe it's hungry...for your $$$$
Old Oct 14, 2011 | 04:14 PM
For sure it's hungry for my $$$. According to the stickie I need to redo the driveshafts. I have all the symptoms. Can you tell anything from these pictures? The rotoflex is new but I'm guessing the rest is original. What else should I plan while we're down there?
Attached Thumbnails Um, grumbling from below-front1.jpg   Um, grumbling from below-front2.jpg   Um, grumbling from below-front3.jpg   Um, grumbling from below-front4.jpg
Old Oct 14, 2011 | 04:16 PM
I have a leak or grease buildup behind the rotoflex.
Attached Thumbnails Um, grumbling from below-rear1.jpg   Um, grumbling from below-rear2.jpg   Um, grumbling from below-rear3.jpg   Um, grumbling from below-rear4.jpg   Um, grumbling from below-rear5.jpg
Old Oct 14, 2011 | 04:31 PM
I'm doing what Tom says..."If you order from Advanceutoparts.com you can get the made in the US Neapco u-joints for $12.50
http://shop.advanceautoparts.com/web...5271118-P_17_R
And the centering kit for $31.
Double Cardan CV Ball Seat Repair Kit by Neapco - Part 7-0081NG - Advance Auto Parts
So $68. Add another u-joint to do the rear, or in case you screw one up, and it's $80.50 and you get free shipping."
So I need the 4. Then on to the differential I guess.
And then I'm fully greaseable or I need to do that bent tip method?
Old Oct 14, 2011 | 04:39 PM
You think you need that centering ball kit on a D1?
While on the underside, check connections and clean up on starter and cables, diffs and transfer case drain & fill (many go back with 85W140, think about it), transfer case reseal inspection plate, both axles pull out banjo bolt that vents the diff oil (clean it and blow out lines), service swivels, inspect front crank seal for leak, tranny fluid and filter change - that enough for Saturday?
Old Oct 15, 2011 | 05:29 AM
You don't think (or you know) I don't need the centering ball kit? It won't be getting done Saturday and it won't be getting done by me...although let's see how far I can take this.
Old Oct 15, 2011 | 06:05 AM
I thought you had a D1, and I just did mine, think centering is a part for a D2....
