Unstable headlight
Old Jun 26, 2011 | 01:56 AM
pimnmike's Avatar
Default Unstable headlight
Hey guys, I was driving and when I got home my headlight looked like it was dangling. I snapped it back in, but it's still feels a little loose. Any suggestions on how to tighten it so it doesn't fall of when I'm driving. I have looked for a thread but can't find one. Thanks for the help guys.
Old Jun 26, 2011 | 02:05 AM
Chris-bob's Avatar
Sounds like either the headlamp housing(hope not) sockets are worn or the headlamp studs are worn.
(that is assuming you are talking about a land rover)
Old Jun 26, 2011 | 06:46 AM
pimnmike's Avatar
Yes Chris-Bob I have a '97SE7. When facing the engine I can actually press on the bottom inside corner and it pops out of the sockets. I hope I can change the bolts and that'll work.
Old Jun 26, 2011 | 07:19 AM
Rovin4life's Avatar
download rave and read the directions on light installation and removal. you may not need all the parts you think you need.
Old Jun 26, 2011 | 08:36 AM
kenk's Avatar
If the plastic tabs came out of the slots behind the headlights, they just go right back in, then grab the plastic tab and swing it about an 1/8 turn, you will see a notch where thy go.
If the ball-and-socket is worn itself, this is what you need:Land Range Rover Discovery Factory Genuine Aftermarket Headlamp Adjuster
Old Jun 26, 2011 | 09:42 AM
Danny Lee 97 Disco's Avatar
One of my headlight adjusters was broken, I replaced them all. They were pretty cheap. AB and RN both stock them.
gmfain
Feb 16, 2015 09:37 AM
camgkh
Jan 18, 2015 11:42 AM
JJ Kelly
Mar 2, 2010 06:29 AM
Disco03
Dec 1, 2008 08:08 PM
igriego
Jun 25, 2005 08:48 PM
