Upstream (front) O2 sensor electrical connector access?
Old Apr 5, 2013 | 11:42 PM
Walko327's Avatar
recently while working on tcase, i was able to reach over the tcase and disconnect the o2 sensors.scrapes and cuts and tight spot. though i did have a bunch of exhaust and drive shafts off giving me more room.
Old Apr 6, 2013 | 07:29 AM
TOM R's Avatar
just be careful changing them my drivers side was very stuck and i had to heat it to get it off then run a tap in the bung for the threads to install the new one
Old Apr 6, 2013 | 09:42 AM
archaeology_student's Avatar
Thanks for the replies
I followed the route everyone else does. A little penetrating Kendall oil on the sensors themselves, let the engine warm up a little bit, use the wrench and they come right out.
This time it has just been getting access to the electrical connectors to unclip.
Will be removing coil pack this weekend, and seeing if I can swap them tomorrow
Old Apr 7, 2013 | 12:30 AM
Well, I was not able to remove the coil pack but I did get just enough room by removing the H.T. Leads (plugs from the coil pack). The drivers side connector sits on a metal tab which keeps it on the bell housing... A little brute force and I was able to bend that tab and then disconnect the connectors!
Unfortunately I stripped the O2 sensor nut... Deep socket set to the rescue after snipping the wires.
Passenger side was easy as I snaked my hand up just as pinkytoe69 mentioned... Took some fiddling (easier than the drivers side for sure) and it clicked out.
Popped in the new passenger sensor, and drivers side tomorrow.
The ECU threw a tonne of codes relating to the O2 sensors but I reset them using an OBD2 Bluetooth adaptor and Torque (Android app) on my Samsung galaxy 2 10.1 tablet.
Vehicle certainly purrs nicely even with only 3 new and functioning O2 sensors
Old Apr 7, 2013 | 08:27 AM
TOM R's Avatar
you will need to run a tap in the pipe like i did, the threads are finiky
Old Apr 7, 2013 | 10:41 AM
fishEH's Avatar
What happened that you couldn't get the coil pack out?
Old Apr 7, 2013 | 01:19 PM
I couldn't find my blasted ratchet... all I had was a screwdriver handle with the socket, but not enough leverage to turn the nuts loose
Old Apr 9, 2013 | 09:47 PM
Thumbs up
Had to torch the driver's side O2 sensor, and finally got it out Threads seemed fine, and feels good to have all the O2 sensors working now
Old Apr 11, 2013 | 09:47 PM
Question
Well, when I got home I heard some rattling underneath yesterday. I checked to find that the passenger upstream O2 sensor electrical connector had come loose... I crawled underneath and plugged it back in, making sure I heard the "click".
When I got into my Rover today it ran really rough
Accelerating is shaky and it shudders a lot... CEL came on and my reader gave me code p1316...
I checked all the leads, which were replaced three months ago as well as plugs...
Any ideas on what I am missing? Perhaps MAF requires cleaning?
Old Apr 12, 2013 | 07:20 PM
keoni004's Avatar
You moved your HT leads...you check those to make sure they're all tight and in the right order?
I'm diving in to replace my O2 sensors tomorrow. Hopefully it goes well.
Last edited by keoni004; Apr 12, 2013 at 07:21 PM. Reason: Actually read your post. Worth a triple check?
