V8i intermittent starting problem
Old Jan 4, 2021 | 11:02 AM
DerekNeil's Avatar
Default V8i intermittent starting problem
Hi All, need help with the following intermittent starting problem. The other day i did some heavy towing with my Disco for about 30 to 40 minutes. Reversing the trailer at the end of the trip i stalled the engine, then when i tried to re-start i couldn't. When i turned the ignition key switch everything worked as usual except the engine did not turn. After waiting 20 to 30 minutes it still would not start, in desperation i disconnected and reconnected the battery and it started. The problem has not returned again. Reading through threads on this and other forums i have seen possible problems being mentioned as starter relays, fuel pump relays, crank position sensor, neutral safety switch on the transmission and others.
Any guidance or suggestions how to fault find this would be appreciated.
Old Jan 4, 2021 | 12:31 PM
disco96sd's Avatar
relays relays relays - LR weak link
Old Jan 4, 2021 | 04:09 PM
hrhoward's Avatar
Since it cranked and started after you disconnected - reconnected the battery, I'm guessing you had a bad connection at the battery. Check positive from battery at the starter and negative fom battery to wherever it goes (can't remember). I'd go ahead and put an extra ground or three in as well. ( block to frame, body to frame, etc.)
RJ5
Apr 9, 2021 04:14 AM
Huskie
May 20, 2018 02:11 PM
nickm347
Dec 6, 2016 04:34 AM
shady milkman
Aug 31, 2012 04:58 PM
DCfromCapeCod
Nov 10, 2010 08:39 PM
