Delay in engine crank after turning the key
Old Dec 5, 2016 | 10:55 AM
nickm347's Avatar
Default Delay in engine crank after turning the key
EDIT: I replaced the ignition switch and it resolved the problem.
2002 4.0 SE 110k miles
The problem is intermittent. When I turn the key, nothing will happen for a second or two, then the engine cranks and starts.
Sometimes it acts normally.
Sometimes I turn the key and nothing will happen, so I turn it back to the 1 position, then back to the crank position and it will start.
It always starts.
The key goes into the ignition barrel without issue.
Items that could potentially be a problem, but have been replaced recently:
-Battery
-Crank Sensor
-MAF
My guess is it's either an ignition switch or a ground cable.
Has anyone experienced anything similar? I'd like to try and pinpoint possibilities before I unnecessarily replace parts.
Thanks
Old Dec 5, 2016 | 02:54 PM
OffroadFrance's Avatar
It always starts.
-Battery
-Crank Sensor
-MAF
Thanks
My money is on a bad earth ground or even a dirty exciter wire connection.
Old Dec 5, 2016 | 03:32 PM
Charlie_V's Avatar
I'm going to guess a loose/dirty connection at the battery, a failing starter solenoid or loose connection there, or the ground behind the driver side head (to the firewall) isn't tight.
I know, alot of guesses, but that hasn't happened to me before/yet.
Old Dec 5, 2016 | 07:52 PM
number9's Avatar
Do you hear any relays or the solenoid when nothing happens?
Old Dec 6, 2016 | 04:34 AM
The Deputy's Avatar
This^^^^
A lot of good advice already, and yes...clean, tight connection and battery quality are paramount to starting a vehicle...so these are good areas to rule out first.
However, if you turn the key and hear absolutely nothing...your ignition switch or starter relay (if LR uses one, not sure...talking generic here) may be getting bad.
Brian.
TxDiscoII
Aug 15, 2011 03:37 PM
LordOphidian
May 15, 2008 08:32 PM
Tanrover
Nov 26, 2006 04:09 PM
05LandRover
Off Topic
Oct 15, 2005 12:30 PM
