Very Sloppy Steering
Old Jan 29, 2019 | 08:45 PM
RBSDISCO's Avatar
Default Very Sloppy Steering
I appreciate all help as I have a work trip tomorrow and this came up tonight. 1998 D1, ZF, ABS 80k I replaced all the bushings on the front and rear suspension, all 4 tie rod ends, front wheel bearings along with many other things over the last 4 months of ownership. I was having some wobble at 65-70 mph which I thought was death wobble til I had death wobble after replacing everything but before alignment. That’s all cleared up but now the steering is super loose. I can turn the wheel from 9 o’clock To 3 o’clock and stay in my lane. When leaving from a stop or low speeds it’s tighter. I know nothing of swivel ball preload but I have read a lot this evening on it and the bearings for the king pin. I have to fix it tonight so thank you for your help.
Old Jan 29, 2019 | 09:40 PM
If memory serves there is adjustment in the steering box as well. Do a little at a time
Old Jan 30, 2019 | 07:43 AM
RBSDISCO's Avatar
Yes sir there is, I was looking through older posts and the same person kept saying not to mess with that, the issue is somewhere else. I adjusted the steering just a little like you suggested and it feels like a whole new car. Amazing. Thank you so much. I have learn to listen to some and others less, small adjustments are always best.
Old Jan 30, 2019 | 04:53 PM
No worries glad to help
emtuzas
Mar 20, 2019 03:22 AM
RoverLife_
Range Rover Classic (1st Gen)
Nov 13, 2018 10:12 AM
DiscoBlanco
Oct 5, 2012 08:51 AM
MiamiC70
Jul 26, 2011 09:38 AM
texmanmoore
Apr 29, 2008 01:23 PM
