Voltage
seems low. where are you measuring from?
if its the obd2 reader try measuring from the back of the alternator and the alternator case. if theres a difference, more than around .2 volts or so, you got a bad connection or corroded cable. in my experience most likely the body ground attachment or alternator cable
body ground is held on by a 10mm nut between the battery and underhood fuse box.
battery to chassis is by the radiator outlet
engine to chassis ground is by the starter.
My mechanic says a battery on the way out draws more from the alternator. This can lead to low voltage, or worse, alternator failure. 13.8 to 14.4 V is typical running voltage for a fully charged battery. 12.6 V is typical resting voltage, fully charged and no load on the battery, that is cable disconnected.
