Voltage
Old Mar 23, 2023 | 02:44 PM
John Carlson's Avatar
Default Voltage
What voltage should the Disco 1 run at? I was going between 11.3 and 12.9, so i got a new Alternator and i'm up to 12.3 to 13.5 now. Shouldn't it be up in the 14 range?
Thanks!
Old Mar 23, 2023 | 07:52 PM
robertf's Avatar
seems low. where are you measuring from?
if its the obd2 reader try measuring from the back of the alternator and the alternator case. if theres a difference, more than around .2 volts or so, you got a bad connection or corroded cable. in my experience most likely the body ground attachment or alternator cable
body ground is held on by a 10mm nut between the battery and underhood fuse box.
battery to chassis is by the radiator outlet
engine to chassis ground is by the starter.
Old Mar 23, 2023 | 08:17 PM
Harvlr's Avatar
With the engine running 13.5 would be a bit lower than you’d like to see. Anything less is too expensive low. As said above make sure all your contacts are clean.
Old Mar 24, 2023 | 09:32 AM
JohnZo's Avatar
My mechanic says a battery on the way out draws more from the alternator. This can lead to low voltage, or worse, alternator failure. 13.8 to 14.4 V is typical running voltage for a fully charged battery. 12.6 V is typical resting voltage, fully charged and no load on the battery, that is cable disconnected.
humroot
Dec 23, 2022 07:45 AM
Petru
Apr 12, 2021 10:12 PM
ljdiscovery
Jan 16, 2021 06:05 PM
redwhitekat
Jul 30, 2018 06:28 AM
Twix
Apr 8, 2017 04:32 AM
