VSS location
Old Jan 2, 2013 | 06:29 PM
coldstart's Avatar
Default VSS location
Where is the VSS located and does it have anything to do with the ABS ,thanks
Old Jan 2, 2013 | 08:03 PM
keoni004's Avatar
"Vehicle speed sensor
The vehicle speed sensor is located on the transfer box behind the transmission brake. The unit has a multirole as the vehicle electronic speedometer sensor and as a sensor for ’surge damping’, (a function which smooths out engine response to sharp accelerator movement and reduces vehicle ’bucking’)."
Page 234 of the D1 workshop manual.
Old Jan 2, 2013 | 08:24 PM
coldstart's Avatar
thank you , I do not have any drivability problems but I am curious if it has anything to do with the cruise not working.
Old Jan 2, 2013 | 09:29 PM
Cruise not working most of the time is bad vacuum line.
Old Jan 3, 2013 | 08:04 AM
WaltNYC's Avatar
If your VSS was bad you'd likely have other problems like a non-functioning speedometer or a truck that won't hit speeds over 40 mph.
FWIW, it is on the left hand side of the transfer case, just in front of the parking brake drum/cylinder.
Attached Thumbnails VSS location-waltnyc-20440-albums-component-locations-805-picture-vss-location-4389.jpg
Roveroh
Aug 7, 2008 09:42 AM
BMartin318
Dec 19, 2006 12:21 AM
anonimaus
Sep 5, 2006 08:37 PM
sergramos
Jul 17, 2006 06:57 PM
dchyun
Jun 4, 2006 06:03 AM
