Sponsored by: CARiD
VSS Problem?
Old Jun 3, 2006 | 03:28 PM
dchyun's Avatar
8th Gear
Default VSS Problem?
I have 99 disco I.
When I speed up on freeway it runs fine, until I reach 80 mph. When I let go the gas and speed down to 70 mph then I try to speed up car, it loses all the power, engin does not want to pick up. So I let it slow down to 55 then it will run fine again.
I changed VSS last night, there is no change in condition. However when I pulled VSS, there was some kind of oil between connectors. Is that normal?
Is that oil there for purpose? Or should I clean that out?
Is this tune up problem? Because it seemed to make some differance when I changed fuel filter.
Please help with all your expertise.
Old Jun 4, 2006 | 02:56 AM
Bait's Avatar
Default RE: VSS Problem?
80 mph in a D1? You are a brave soul. Is the check engine light on? Have you pulled the engine codes?
Old Jun 4, 2006 | 06:03 AM
mikemeyer0's Avatar
doesn't really sound like a VSS problem, was the speedo bouncing back and forth from speed to zero? also its prolly eletrical connector greese in that connection (electrical connection, right?)
tcbinaflash
Nov 27, 2018 06:32 PM
bulldoggergal
Jul 15, 2007 07:26 AM
BMartin318
Dec 19, 2006 12:21 AM
anonimaus
Sep 5, 2006 08:37 PM
sergramos
Jul 17, 2006 06:57 PM
