Water Pump and Thermostat replacement
Old Nov 3, 2014 | 08:15 PM
rubbamade's Avatar
Default Water Pump and Thermostat replacement
1998 Land Rover Disco 1 V8i 4.0L
So while replacing the water pump, I figured I'd go ahead and change the thermostat. everything went great. BUT, when I went to put the thermostat housing back in its place, I noticed I had misplaced the 2 bolts for the housing. I've had no luck finding them.
My problem is I cannot find the dimensions for the bolts anywhere. I also came across a thread the suggested replacing the bolts with studs and capping them with a nut. I actually think that is a great idea, but it did not mention the dimensions of the stud or bolt.
If someone can fill me in on the size and thread count measurement of the bolts I would greatly appreciate it. Its the 2 bolts that attach the thermostat housing to the engine block.
Old Nov 4, 2014 | 01:39 AM
Gimebakmybulits's Avatar
They are SAE and the factory ones are a little longer than 3/4" but I used the 3/4" flange bolts that I found at the hardware store. I'm pretty sure the thread is 5/16-24, I'd have to run by the store and check their thread gauge to be positive though.
mln01
Jun 12, 2014 07:23 AM
DonRW2007
Feb 25, 2012 05:32 PM
Tara Elliott
Feb 17, 2012 09:42 PM
