water pump tips/tricks
Old Oct 6, 2013 | 01:25 PM
nuclearw's Avatar
Default water pump tips/tricks
Got he water pump and fan clutch, i remember seeing some people having issues with doing the pump, and i'd like to not have a fight too much, or go without the truck for a while if possible.
So few questions then request for general feedback / advice.. hopefully again this thread may help someone else.
#1. Do I, or should I replace bolts for the water pump?
#2. Any issues with removing the bolts? I remember reading something about them getting stuck, but couldn't find the thread again.
#3. Touch of rtv on either side of the gasket to help ensure seal? Or just use gasket by itself.
#4. with the chevy fan clutch, do I need different bolts for the fan as well? or just enlarge the holes in the fan to fit a different alignment.
that's what I got for now. Im big on being prepared so i'd rather have what i need up front, thanks
Old Oct 7, 2013 | 11:00 AM
SSL9000J's Avatar
The alignment is identical, the holes just need to be larger. You will, however, need to replace the bolts. (LR clutch is metric, Chevy will be SAE.) I think they're 3/8-16 by 1/2"; easily obtainable from your local hardware store. Wouldn't hurt to add lockwashers as well.
Old Oct 7, 2013 | 08:09 PM
nuclearw's Avatar
Thanks! I'll stop by ACE on the way home and grab them
Snafu / Disco Fries
Dec 1, 2011 11:54 AM
BFox15
Aug 21, 2011 08:48 PM
mpparamedic
Jul 24, 2010 06:55 PM
shawn
Dec 21, 2007 11:53 AM
shawn
Oct 4, 2007 09:10 PM
