WD-40 and your engine
Old Nov 17, 2011 | 10:44 AM
Discolife's Avatar
Originally Posted by wheelgarage
Used Water Displacement 40 for years.... I'm now using Blaster, which works really good. From personal experience with built up LR grime, it cleans really nicely...really loosens up the dirt.
I have been afraid to use that liberally. If it works then great. I do use that on axles etc. just not under hood.
Old Nov 17, 2011 | 12:08 PM
wheelgarage's Avatar
Yeah...had to use it, just due to the fact I ran out of parts cleaner. Desperate...I reached for the Blaster....
Old Nov 20, 2011 | 11:50 AM
tornado_735's Avatar
Wd-40 is about 50% Aliphatic Hydrocarbon
which is deoderized kerosene...
I think WD-40 smells pretty good....LOL!!!
Old Nov 20, 2011 | 10:10 PM
atancreti's Avatar
I have said this before: I literally spray the entire underside of the disco to "prevent" rust... It works! I put it on to the point its dripping off as well. Or hell, motor oil works as well. Just don't "soak" electrical wires. Anything to divert the water from eating away our steel frames.
Old Nov 20, 2011 | 10:14 PM
Discolife's Avatar
Thats good to hear. It does work and work well. I figure since these trucks have an issue with dried up corroded connections it cant hurt at all
Old Dec 2, 2011 | 05:16 PM
SenatorPerry's Avatar
Thanks for the suggestion... Sprayed down a few areas under the hood and followed behind with a tight low pressure directional spray on a pressure washer. It made a huge difference.
I was thinking that since the chassis is so easy to reach mid-body that it would help to do some chassis paint. Looking through the forums it doesn't appear anyone else does that. Is there some reason for this?
Old Dec 3, 2011 | 08:47 AM
Discolife's Avatar
Thats the way to use it. I'll bet my landy hasn't been this clean since new. Mud falls off easier too.
My motor has that new smell to it now.
ngarover
May 17, 2011 09:16 PM
DURABLEOILCOM
May 6, 2011 12:03 PM
Antmen
Off Topic
25
Apr 30, 2010 11:12 PM
Mrmerlin
Dec 10, 2009 03:10 PM
