Weird issue
Old Oct 30, 2012 | 03:25 PM
GamecockRover's Avatar
Default Weird issue
So I turned the heat on in my rover the other morning and after about 10 minutes it started to overheat. I turned off the heater and the temp gauge returned to normal after ab 1 minute. It has not overheated since ... What would cause it to overheat only when turning on the heat?
Old Oct 30, 2012 | 05:29 PM
Soccer Dad's Avatar
No connection between the two events.
The temp sensor could be failing, or the wiring faulty (shorting(ish) throu the heater wiring circuit).
you need a Temp multimeter with temp probe inserted between the rad fins to somewhat accurately measure the coolant temp. Then put the heating on and see if the coolant temp surges.
Yeah, weird symptoms.
Easiest test is to replace the ECT sensor (Engine Coolant Temperature)
SD
AnnelieseMae
Feb 24, 2009 12:14 PM
Brad S1
Apr 21, 2008 04:33 PM
rravenn13
Oct 3, 2007 03:28 PM
Brad S1
May 8, 2007 03:21 PM
khtemple
Sep 14, 2006 06:00 AM
