Well, I'm buying it
Old Aug 31, 2017 | 11:13 AM
jastutte's Avatar
Originally Posted by maybediscobuyer
. Gonna check the 4wd and make sure it's still moving right,
Any quick and easy things I should do?
You may already be aware but just in case you aren't, these trucks are full time All Wheel Drive. So, you are always in "4 wheel drive". The Diff Lock locks the front and rear drive shafts and should only be used off concrete or asphalt. Locking the differentials and driving on asphalt or concrete can mess things up when you try to turn.
Does the truck have the owner's manual? If not, get hold of one and read up on the diff lock.
Old Aug 31, 2017 | 11:24 AM
WaltNYC's Avatar
wires (go with 8mm wires)...
Spark Plug Wires for Defender, Discovery and Range Rover
plugs....
Amazon Amazon
check your serp belt...
Amazon Amazon
drain / re-fill front/rear diffs and xfer case....
Amazon Amazon
check fan clutch...
Amazon Amazon
check/grease u-joints...
Amazon Amazon
and download all the manuals found in the D1 section of the link in my signature.
Old Aug 31, 2017 | 11:55 AM
hrhoward's Avatar
Learn to swear with a cockney accent.
Old Aug 31, 2017 | 02:38 PM
WaltNYC's Avatar
Lesson #1
Old Aug 31, 2017 | 03:37 PM
whiskeynipple0088's Avatar
hahaha - but if you do have to do that just take the console out, drill out the rivets on the boot to tunnel and get to everything from the top
Old Aug 31, 2017 | 08:40 PM
ihscouts's Avatar
I think that comes natural. When you get so pissed nobody understands what your saying they'll sum it up as Cockney.......or Pig Latin.
Danny Lee 97 Disco
Apr 8, 2010 10:57 PM
blueduck
Apr 10, 2007 10:14 PM
steveo
Jun 6, 2005 03:03 PM
ceedee
May 30, 2005 01:01 AM
mke137
May 14, 2005 03:04 AM
