What doesn't work on your Discovery?
Old Mar 31, 2015 | 08:16 AM
  #91
dusty1's Avatar
paul grant linked some great generic replacement cats a couple of weeks ago
Old Apr 3, 2015 | 08:49 PM
  #92
USNAVYORDNANCE's Avatar
Which bungs, the top two or bottom two? Or all 4? Thanks.
Originally Posted by TOM R
i did mine, need to fool the down stream o2
i welded the bungs shut and then stacked nuts on the bung, welded them then screwed the sensors in, it is loud with no cats and a welded muffler, supposed to be able to use spark plug non foulers but i could not source them in the correct size localy
Old Apr 6, 2015 | 11:46 AM
  #93
Sam95disco's Avatar
Have to get more keys, noticed my key had a crack in it. That rear door is the cause of this.
My girlfriend moved my spare and I can't find it.
Old Apr 6, 2015 | 05:00 PM
  #94
MrValingo's Avatar
Headlight sprayers, front pass blinker (bulb good, no light up), cruise, fog lights, drivers seat heater, abs light on, pass power seat sometimes doesn't work and when it stops the drivers power seat will only work with the door open, shift indicator lights and other various switch lights
Old Oct 15, 2015 | 08:27 PM
  #95
tinafrissora's Avatar
Default It wouldn't be a Land Rover if it didn't!
Originally Posted by SSL9000J
Next thread: "What leaks on your Discovery?"
Years ago when our 1st Disco was leaking multiple fluids rapidly, I called a mechanic (that had been recommended by another mechanic who wouldn't touch Land Rovers) and told him it was leaking in like 3 different places. With no hesitation he says, "Well, it wouldn't be a Land Rover if it didn't, now would it?"
Old Mar 13, 2016 | 06:48 PM
  #96
Sam95disco's Avatar
Now the ac doesn't work.
Edit: the comp does work, it came on the other day. So I'll just go have it checked out
Old Mar 16, 2016 | 02:22 PM
  #97
saintdel's Avatar
Fog lights, abs light is on, sun roofs don't lock down, cruise control. Otherwise, it's all good.
Old Jul 24, 2016 | 06:49 PM
  #98
roverlady1's Avatar
Sam95disco abs and airbag light is caused by the cassette in the steering column gone bad. you can get another but make sure that it has not been turned or the small parts break easy.
Old Jul 25, 2016 | 05:20 AM
  #99
s10lowrider1994's Avatar
Central locking doesn't work, key fob works occasionally, rear a/c works sometimes, cruise control is dead. I don't know if is say anything works 100% of the time, there's always something to fix or rig.
Old Aug 17, 2016 | 02:08 PM
  #100
disco-tec's Avatar
Fog lights no workee, cruise is kaput, keyless has mind of its own, ac blows ice cold, heat works okay, (unless below zero, door seals leak), fan speed switch is schizophrenic, radio and cd changer work great, both sunroofs work great, rear door leaks around seal, Subwoofer no workee, besides that shes a good truck.
