What doesn't work on your Discovery?
Old Jan 30, 2019 | 04:58 PM
  #131
hrhoward's Avatar
How is the rear wiper blade?
Old Jan 30, 2019 | 10:35 PM
  #132
mrbieler's Avatar
5th Gear
Rear wiper washer (wiper works)
ABS
Front head light washers (removed)
Cruise control
Rear defroster
Stereo (replaced)
A/C and dash lights (instrument cluster lights work)
not bad for 22 years
Old Apr 23, 2019 | 07:51 AM
  #133
User966's Avatar
7th Gear
Default Anything electric
My right window is off track. Driver side window works well back. Back windows don't work at all, but there's a fuse missing from them. the brake lights weren't working but I figured out what was wrong with them. Somebody forced a double filament in where the single filament goes. None of the tail lights were working on the right hand side but I traced that to a bad ground. The motor is running hot. The water pump is leaking, the radiator is cool on one side and hot on the other, and the fan clutch doesn't seem to be working properly.
Old May 8, 2022 | 07:13 AM
  #134
Sam95disco's Avatar
Updates needed lol
Old May 29, 2022 | 10:29 PM
  #135
Discotime1's Avatar
i could give you a shorter list of what DOES work lol
Old May 30, 2022 | 12:41 PM
  #136
Machinistbutler's Avatar
Rear windows don't work , haven't checked why as front work good. Interior lights too, at least in front, one in the far back works good . Haven't tried cruise yet.
Fun as heck to drive though! I get comments every time I take it out.
Old May 30, 2022 | 12:50 PM
  #137
Discotime1's Avatar
for your rear windows i would suggest taking apart the switches and just giving all the contacts a good clean, the window switches are very basic. i did this and went from having 1 window working to all 4 working perfectly! also a quick test would be to plug a known working switch into the rear window switch wire connector to rule it out at least. a quick google search on how to clean the switch is all i needed to point me in the right direction. but dont forget to re grease the “rocker” pins if you do!
Old May 31, 2022 | 10:35 AM
  #138
denverdisco1's Avatar
Also FYI, there is a button which is the child lock on the rear windows, make sure it's off or not sticking.
I had to fix both rear window rollers with a washer, works well enough since they don't get used often.
Now my alternator just died so will replace it along with the serpentine and tensioner.
Old May 31, 2022 | 12:48 PM
  #139
TomD's Avatar
Default Discovery 2
Don't have any forward gears, only reverse. Just went over speed humb and no gears except Reverse. It works perfectly. Change filter, oil, xyz switch. Changed selinoids. No luck finding forward. You can hear it goes into gear but not moving.
Old Jun 26, 2022 | 05:10 PM
  #140
LR 601's Avatar
3rd Gear
Default A very short list
rear sunroof
cigar lighter
left rear door electric window
