Wheel lug nuts....whats the poop?
Old Apr 5, 2013 | 01:34 PM
RacerX's Avatar
Default Wheel lug nuts....whats the poop?
I did a couple searches which yielded no results....what's the poop on wheel lug nuts? The stock/OE "crown/capped" nuts are ricockulously expensive for some reason. I thought I recalled reading somewhere that one should not use the stock nuts with steel wheels and one should use proper steel lug nuts. Can the the steel nuts be used with the stock alloy wheels? On all my cars I use alloy wheels (stock or aftermarket) and generally switch from bolts to studs. I've used both aluminum (teh suck) nuts but generally use steel.
Just trying to understand this on the rover side. Is there a seat difference on say a NATO steel wheel vs stock alloy such that different nuts are required?
Point of all this is I am switching from a set of NATO steel wheels back to stock alloys and I only have the nuts that came with the NATO's. I was going to just buy stock nuts but as indicated above they are cost prohibitive unless there's a reason to use them.
Thanks.
Old Apr 5, 2013 | 02:30 PM
jafir's Avatar
You cannot use steel wheel lug nuts on the alloys. The correct nuts ar expensive, about $5 each here: RovahFarm for all your new Land Rover Parts and Accessories
You might try used from one of the usuals.
Old Apr 5, 2013 | 02:36 PM
RacerX's Avatar
Why can steel lug nuts not be used on the alloys? Different seat or something or ???
cheers.
Old Apr 5, 2013 | 03:19 PM
jafir's Avatar
cheers.
The alloy lugs nuts can be used on steel wheels, since they have the taper, but I think the steel wheel lugs aren't the right shape for the alloys. The alloy lugs have a big shoulder and washer. They might pull right through if used on an alloy. Not sure about that though.
Old Apr 5, 2013 | 04:28 PM
Rover_Hokie's Avatar
Call Will Tillery, 434-251-9331, he will get you some used ones out ASAP, I picked up a five from him last week to have for spares.
Old Apr 5, 2013 | 08:37 PM
Once you see the alloys you will understand.
You need to buy used, look for a set of Range Rover Classic lug nuts, they are solid steel and not capped like the DI lug nuts.
Thats the route I went, they were tarnished and I had to clean them up, but they cleaned up nice and work great.
$35 shipped from a forum member in the classifieds.
Check e-bay too.
Old Apr 6, 2013 | 07:48 AM
RacerX's Avatar
Ok so the alloy wheels seat on the cone and the flat, makes sense then. Thanks all!
Old Apr 6, 2013 | 02:38 PM
jafir's Avatar
Check e-bay too.
I thought you had wolf wheels?
Old Apr 6, 2013 | 02:44 PM
I have both.
Winerforce on the Wolf's, S/T's on the alloy's.
Old Apr 7, 2013 | 09:47 AM
RacerX's Avatar
I currently have NATO's but will sell those and switch back to stock alloys. I prefer the alloys and I only need one set of wheels/tires....I think the only vehicle I own that has one set, heh.
Spike...thanks for the heads up on the RRC lugs, that's the way I'll go, I don't care for that capped style.
Cheers.
