Wheel Spacers
Old Jul 20, 2010 | 08:22 PM
Long Haul's Avatar
Originally Posted by antichrist
The idea of spacers, and least for me, was to allow taller tires without rubbing the radius arms, and therefore a somewhat smaller turning radius. Adjusting the steering stops wouldn't have accomplished that.
X2 that was my problem also.
Old Jul 21, 2010 | 01:28 PM
Roverrocks's Avatar
I have had spacers on for 3 years with no issues. I put them on so my 32" MT's would not rub my radius arms. I'm very glad I installed them. Not only does the wider stance look good but I believe my D1 handles better on road and off road. Greater stability. I do a lot of off roading and have had no issues of any kind.
Old Jul 21, 2010 | 03:08 PM
XCELLER8's Avatar
what brand did you get ? and how wide ?
Old Jul 21, 2010 | 04:11 PM
Soccer Dad's Avatar
I am pleased with the replies.
Please describe your setup:
* thickness:
* price:
* source:
* tyres:
* problems:
I am sure many others are interested.
SD
P.S.: if you know of sources to avoid, please say so.
Old Jul 21, 2010 | 05:24 PM
antichrist's Avatar
Thickness I'm not sure exactly on, but slightly thicker than the distance from the hub face to the end of the stud.
I think around $200 for two (I got them about 7 or 8 years ago)
From RTE
Cooper 7.50R16 Discoverer STT (old style) and also 7.50R16 Goodyear G90's
No problems.
Old Jul 21, 2010 | 06:02 PM
Long Haul's Avatar
I had Toddco spacers with 32x10.50 mts. I think they were $400 for the set about a year ago. The only problem I had with them(not spacers fault) is that the lugs come loose on the spacer after about 5miles i retourqed them and never had a problem after that.
Oh yeah forgot to add they are 1.5" thickness.
www.toddcosuspensions.com
Old Jul 22, 2010 | 11:18 AM
Roverrocks's Avatar
Bought my 1 1/4" spacers out of Rovers North. They are Proline Performance aluminum alloy spacers. Not cheap though at $429/kit I think it was. Have had no issues knock on wood. I like the benefits they have given me. Probably can be gotten cheaper elsewhere.
Old Jul 23, 2010 | 06:12 AM
antichrist's Avatar
If all you're trying to do is help your turning radius, you only need them on the front. I've had no issues running them only on the front.
Old Jul 25, 2010 | 07:03 PM
antichrist's Avatar
I measured my spacers today. They are 30mm. Pretty standard.
tastandish
Apr 2, 2017 01:47 PM
JBeezy53
Jun 14, 2009 11:34 AM
98roverguy
Jul 16, 2007 05:28 PM
jmerrill
Dec 6, 2006 11:59 AM
beekers
Dec 6, 2006 02:11 AM
