where is the crank and cam postion sensor? pics please
Old Oct 31, 2010 | 04:17 PM
booper169's Avatar
Default where is the crank and cam postion sensor? pics please
can someone show me pics of where they are located??? 1998 disco 1
Old Oct 31, 2010 | 04:33 PM
They very rarely go bad on a DI.
What is the problem and what have you done to try and correct it?
Old Oct 31, 2010 | 04:43 PM
booper169's Avatar
its running super rough and barely idling... stalls too... misfires while driving.. ive ordered a set of 8mm magnecor wires and gonna get new plugs too once i decide which ones will work best....
booper169's Avatar
could it be 02 sensors or do they not do that?
Old Oct 31, 2010 | 05:04 PM
No O2's will not cause that.
How long have you had the truck?
How many miles on it?
Old Oct 31, 2010 | 05:20 PM
booper169's Avatar
What would bad o2s do?
Old Oct 31, 2010 | 05:32 PM
Bad O2's will cause over fueling or lean running.
O2's help control the air/fuel mixture, thats all they do, nothing more nothing less.
The ECU takes inputs from the air intake temp sensor, the MAF, the coolant temp sensor, the throttle position sensor and the O2's to determine how much fuel you need.
The crank sensor tells the ECU the engine is running and to supply power to the fuel pump as well as spark.
The knock sensors retard or advance ignition timing based on fuel quality and load on engine.
The cam sensor controls injector timing.
Old Oct 31, 2010 | 06:07 PM
Danny Lee 97 Disco's Avatar
Great info Spike, I learn a lot on here with those kind of explanations. Keep up the good work.
Old Oct 31, 2010 | 06:34 PM
booper169's Avatar
Thanks for the info any idea what my problem could be?
Old Oct 31, 2010 | 08:08 PM
Once you install the copper spark plugs and new plug wires we can go from there.
How long have you had the truck and how many miles on it?
