where is the crank and cam postion sensor? pics please
Old Oct 31, 2010 | 08:23 PM
booper169's Avatar
What spark plug work best with 8mm wires? The truck has 270k andhad it a year
Old Oct 31, 2010 | 08:39 PM
Just get cheap copper plugs, it came with Champions.
270,000 miles or kilometers?
Old Oct 31, 2010 | 08:44 PM
booper169's Avatar
Could bad wires be the problem
Old Oct 31, 2010 | 08:51 PM
YES!
Bad plugs and wires is where I would start.
The GEMS engine has default settings for everything, so if the cam sensor fails, the engine will still run.
Crank sensor fails...still runs.
TPS...still runs.
It will run like crap, but it will still run.
With that in mind and with the price of those parts and and the difficultly replacing those parts when ever working on a car remember this.
K eep
I t
S imple
S tupid
In other words, start with the simple/cheap stuff first, like plugs and wires.
Old Oct 31, 2010 | 09:21 PM
booper169's Avatar
Ok I'll replace the wires and plugs and let you know.
Old Nov 1, 2010 | 07:41 AM
giboulou13's Avatar
8th Gear
Smile
can someone show me pics of where they are located??? 1998 disco 1
the camshaft sensor is located on the timing chain cover below the water pump ant the crank sensor should be on the side of the eng towars the back near trans.
Old Nov 1, 2010 | 04:45 PM
Danny Lee 97 Disco's Avatar
One of my spark plug wires broke off right at the plug, they were Lucas, most likely original set from 1997.
Old Nov 1, 2010 | 06:58 PM
bmxermike's Avatar
same here
thehun
Mar 7, 2013 01:35 AM
cgeschwell
Feb 23, 2011 01:01 PM
Shane83
Mar 8, 2010 11:21 AM
sheelhorse
Jun 25, 2009 10:39 PM
roverwoody
Sep 12, 2008 04:51 PM
