Whining Disco
Old Jul 14, 2012 | 01:09 PM
b63215b's Avatar
Default Whining Disco
So I read the entire thread from Rick1701 about a whining noise. I am not very versed with these type of things. I am having the same problem myself, it is weird though I have had it parked for a week and a half I just started it to move it and it started whining. I never had the whining problems before. At this point it only seems to whine when the wheels are turning. Thanks for any help
Josh
Old Jul 14, 2012 | 01:21 PM
ToddD's Avatar
They all whine. Needy slags.
Your description is lacking. Is it belt / power steering related? Is there power steering fluid in it? I could throw darts at this one all day!
Old Jul 14, 2012 | 01:47 PM
b63215b's Avatar
I know I will get a better description soon. I just wanted to somehow get started I was a little bummed that is started making that noise.
Old Jul 14, 2012 | 02:49 PM
A whine when turning can be a simple as low power steering fluid (it is really red automatic transmission fluid or ATF), or can be pump problems.
Old Jul 14, 2012 | 07:14 PM
b63215b's Avatar
Default Low Fluid
There is low fluid but I have none to replace and see if that was the problem. I get back to everyone on that.
Josh
Old Jul 14, 2012 | 08:40 PM
Jake1996D1's Avatar
Tell that bitch to stop whining
Old Jul 14, 2012 | 11:21 PM
oh - and that "very little engine knock" - might want to use 15W40 Rotella see https://landroverforums.com/forum/di...estions-46975/), or even 20W50, and read the write up in tech section on main bearing replacement (https://landroverforums.com/forum/di...rite-up-48197/).
Old Jul 15, 2012 | 12:55 AM
Bkreutz's Avatar
Or get some cheese to go with it.
Old Jul 15, 2012 | 12:24 PM
ToddD's Avatar
x2 on the cheese.
My rig has a PS fluid slow leak and will whine a bit when the fluid is low. It's been a very long time since I've had to add fluid. It didn't look low but it took a surprising amount when I added.
Old Jul 15, 2012 | 02:04 PM
b63215b's Avatar
Thanks, I will add some more and see what happens. Does any brand work better than others, and should I add the Lucas PS leak stuff? To note, I have never seen a leak!
