Why can't the auto trans be a 5speed on a disco?
Old Mar 11, 2014 | 06:21 PM
Sam95disco's Avatar
Default Why can't the auto trans be a 5speed on a disco?
Anyone know why?
Old Mar 11, 2014 | 09:49 PM
abran's Avatar
Not sure I understand your question, but if you are asking can you make your automatic car a manual... Yes.
Need:
Pedal Assembly
Shifter Assembly
Flywheel
Master Clutch cylinder
5 speed trans with bell housing
manual trans oil cooler lines
I just happen to have all of that for sale...(except the trans oil cooler lines)
Old Mar 11, 2014 | 10:12 PM
Sam95disco's Avatar
Need:
Pedal Assembly
Shifter Assembly
Flywheel
Why can't the 4spd auto be a 5spd auto?
Old Mar 11, 2014 | 10:20 PM
tuercas viejas's Avatar
It is if you count the overdrive and the lock up feature.
Sorry curious question??
T/V
Old Mar 11, 2014 | 11:06 PM
Because they didn't make it that way.
Old Mar 12, 2014 | 01:13 PM
jafir's Avatar
The auto in a D1 has no electronics. You could stick whatever non-electronically controlled auto behind it that you can make fit, and the computers won't care.
The D1 came out in 1990, and a four speed auto was pretty normal for the time. If there were 4 speed autos, they were likely only on very high end cars, not cars that were basically designed on top of a 1970 Range Rover Classic.
Old Mar 12, 2014 | 02:36 PM
Sam95disco's Avatar
So the tech wasn't around, thats why its only 4? So the 5spd man is 12345 and r or 1234 and r?
Old Mar 12, 2014 | 02:55 PM
EricTyrrell's Avatar
5 speed means 1,2,3,4,5,R
4 speed autos were normal for a long time. They work fine.
Old Mar 12, 2014 | 08:24 PM
Sam95disco's Avatar
So the 5spd gets better mpg right?
Old Mar 13, 2014 | 06:33 PM
jafir's Avatar
Usually, due to less rotating mass and a direction connection to the engine as opposed to the fluid coupling the auto uses.
But in a disco, I'll bet it's not much better. Maybe 1 or 2 mpg.
