Will the Bosch PCV adapter fit a GEMs valve cover
Old Today | 11:51 AM
disco96sd's Avatar
Default Will the Bosch PCV adapter fit a GEMs valve cover
Had a slight variation in idle speed the other day - it persisted for a couple of days - opened the hood and looked around - all appeared to be good - but upon closer inspection noticed the crankcase breather hose had perished on the plenum connection obviously causing a small vacuum leak - it perished on the very end so I cut it off and reattached alleviating the vacuum leak and idle variation - have a new hose ordered for $9 - guess I could have used some hose I had but will give a parts house $9 for the proper part (that included shipping)
Ok went to change the hose and when I pulled the hose off on the valve cover the little barrel pulled out with the hose - my question is should I just pound it back in and lock tight it in or could I use the Bosch D2 PCV adapter ? not sure if the GEMs and Bosch valve covers are the same that this would screw into the valve cover ?
Let me know if you have an opinion
URO Engine Crankcase Breather Hose for Discovery, Range Rover ERR4258 - Picture 1 of 4
LAND ROVER INTAKE MANIFOLD PCV VALVE ADAPTOR DISCOVERY 2 P38 ERR6880 OEM Intake - Picture 1 of 7
bcurtman
Oct 8, 2019 01:28 PM
sobieski
Nov 3, 2015 08:08 PM
savagekook
Mar 11, 2015 05:55 PM
grandkodiak
May 8, 2011 06:44 PM
Phototone
Apr 5, 2008 02:25 PM
