Tube from right hand valve cover to TB
Old May 8, 2011 | 06:44 PM
grandkodiak's Avatar
Default Tube from right hand valve cover to TB
The hose that goes from the right hand valve cover up to the back of the throttle body, to the top left most port, how should it fit on? i was getting a wizzy noise from it (vac leak) so i unscrewed a hose clamp that was on it, and tried to pull it off... well, the hose is clamped onto another smaller hose, which is jammed in the hole. then i noticed the hole has threading on the inside. im assuming its SUPPOSED to be a thread in piece, that some previous owner just got to lazy to fix? or is it supposed to be like that? its near impossible to get the inner hose back in because of the threading unless you squeeze it with needle nose and push it in... but in any case, i doubt its correct.
devotid
Jul 13, 2012 09:27 AM
Miwo
Mar 16, 2011 02:01 PM
kpbuck2040
Jul 12, 2010 07:16 AM
wizardmagu
Sep 14, 2008 07:00 PM
nvlocal
May 5, 2007 09:09 PM
