Will a headlight power wash pump from D2 fit?
In case I decide to eventually fix the headlight washers, will a D2 pump fit a D1 reservoir?
And in case anyone is interested (like you guys who told me to run away from this one - and you may still be right) so far I have invested the following and as of right now it drives OK (still have to verify the OD in/out symptom at 60), the steering is tight, both the ABS and check engine light stay off, all the windows work (not the sunroofs yet), all the lights work, the front and rear windscreen washers work, the radio sounds good, the AC blows cold, and it cleaned up pretty well.
1998 Disco 1 LE $700 (to save it from the scrap yard)
Passenger side mirror $40
Brake light switch $18
Jack and jack handles $26
Spark Plugs $18
Spark Plug Wires $33
Oil Filter $7
Oil $16
Transmission Fluid $37 (full synthetic Valvoline)
24 Ozs Lucas Transmission Fix $? (had on hand)
3 cans of R134a $? (had on hand)
K & N air filter $18
Side repeater lens $10
Spare tire cover $17
Two weeks of fiddling $0
Total out of pocket so far - $940, Seeing it saved - priceless
Spark Plugs $18
Oil Filter $7
Oil $16
Seven Lucky Logs
09-19-2006 07:25 AM
