Winches
Old Feb 25, 2013 | 08:23 AM
antichrist's Avatar
No that they will fail, just at full load you'll get what I consider to high volt drop, meaning they get warmer/hotter and the winch motor turns slower. #1 would be better, but like I said, unless you run it at full load a lot, you'll be fine with the #2. You can give yourself additional margin by using a ****** block when you can, which is generally better to do anyway.
Old Feb 27, 2013 | 02:35 PM
Walko327's Avatar
Check. This winch is just an insurance purposes for the just in case. Should I wore a fuse in to the circuit though Tom?
Old Feb 28, 2013 | 08:00 AM
antichrist's Avatar
A high capacity (500amp min) disconnect switch would be better than a fuse, located somewhere with easy access in case the winch sticks 'on'.
Old Feb 28, 2013 | 04:35 PM
Walko327's Avatar
Check. Sounds like a good safety measure.
sloan74
Mar 30, 2011 12:52 PM
AtlanticBritish
Member Group And Special Buys
Mar 22, 2011 11:58 AM
meltdowndave
May 15, 2008 06:07 PM
SnowmanJon
Jun 23, 2007 11:40 PM
newBrover
Apr 24, 2007 01:54 PM
