Window ECU soldering
Old Nov 23, 2020 | 06:54 PM
CantComplain's Avatar
Originally Posted by CantComplain
Will the bypass (as documented here: https://www.roverparts.com/Instructi...tRepairKit.cfm) bypass the ECU for the rears entirely, or only whatever issue is caused by a faulty solder joint? If I can just splice a wire to get where I was before, I'd be happy enough for the time being.
Bump. Trying to find our if I can use the wiring bypass to completely negate the broken window ECU and be able to operate the back windows.
To make matters more frustrating for me, I did end up taking the door card off and take a look to see if I could see why the window (US driver's) wasn't working. The electrical was unplugged. So that part is an easy fix. The regulator got horked, so they probably just saved the coin and dealt with a window that wouldn't operate. New one on the way, so I'll have working fronts, but I jacked up the backs with the ECU work that I didn't need to do....
twoxred
Oct 4, 2021 07:07 AM
camminich
Oct 14, 2020 01:54 PM
udt63
Oct 12, 2017 03:46 PM
andy thomson
Feb 13, 2013 06:43 PM
kamileon
Apr 24, 2011 01:17 AM
