Window felt/seal replacement. Driver and Passenger front doors.
Old Mar 11, 2017 | 11:30 AM
Robert Booth's Avatar
Default Window felt/seal replacement. Driver and Passenger front doors.
Anyone done this before? RAVE wants me to pull the window frame, along with the glass. Can I just remove the frame, leaving the glass in place, attached to the regulator?
Also, does the replacement window felt/seal just push into place or is it supposed to be secured by an adhesive?
The ones on my SD are pretty chewed up and beyond saving. I'd ideally like to complete the job without pulling everything apart
Old Mar 11, 2017 | 02:54 PM
OverRover's Avatar
You will need to remove the window frame and glass to replace the seal. The seal goes down the window frame well past the door card (see pic). I use a thin bead of Permatex RTV Adhesive Sealant (comes clear or black) to keep the seal in place.
Old Mar 11, 2017 | 03:23 PM
Thanks for the reply!
i know I have to take the frame out, I was hoping that I could leave the glass in place and just remove the frame.
Old Mar 11, 2017 | 03:48 PM
OverRover's Avatar
I get what you want to do but I've just never done it. I don't even think I considered it being it's just not that much effort to pull the window regulator with the glass taped to the frame. I do know that even with the glass taped to the frame the bottom of the frame rails flex inward like crazy. I would think trying to get the frame over the glass while attached to the regulator would be a PITA, if at all possible.
If you decide to leave the glass attached to the reg please post the outcome. Good Luck!
> Last thought, CHECK the Window Lift Channel (#ALR8022) for rust! I would be very careful trying to remove the frame with the glass and reg attached if the Window Lift Channel is rusted. Remember the only thing holding the glass to the channel is the glazing rubber and pressure. I've seen Lift Channels look fine on the inside facing edge, but the outside is toast from rust. Just replaced a Lift Channel on a '95 RRC for this reason.
Old Mar 12, 2017 | 12:31 AM
jimvw57's Avatar
My pass side window would always make a clunk noise when opening the window. Then it wouldn't close so I shut it with a jumper wires ans disconnected it. I added a short piece of the gasket in the channel that was damaged and just patched it in the upper rear corner instead of replacing the whole thing. It had always leaked air and that made it better.
I am wondering if the channel that is attached to the glass is bad causing the noise. I may have to work on it once it gets warmer outside. I think the window not closing is the computer board under the dash. Already fixed it once (re-soldered the connections) and I suspect it will need that again.
unstable
Sep 22, 2017 08:47 AM
bfamous
Mar 17, 2014 04:16 PM
tsuami1
Jun 20, 2012 10:20 PM
Princess
Sep 15, 2009 08:02 PM
DuplinDisco
Feb 4, 2008 06:30 PM
