window problem
Old Jun 18, 2012 | 11:15 PM
AZlandy's Avatar
Default window problem
hello again everyone, i have a new question. so yesterday the passenger window fell off the track and i finally got around to taking the panel off to see what happened and one of the circular clips is broken causing the arm to pop off when you try to roll the window up or down. so where can i find a new piece (if you can lol ) ? or do i have to replace the whole regulator ?
Old Jun 19, 2012 | 12:19 AM
ToddD's Avatar
What piece are you talking about? Did the white plastic piece that slides side to side fail?
This has happened to me twice, both times I hit junk yards to look for good regulators and replaced the entire unit. If it's just the white piece (most common failure) there are write up's on how to replace those if you're feeling ambitious.
Pics or more info would help. Worth 1,000 words, right?
Old Jun 19, 2012 | 07:28 AM
slanginsanjuan's Avatar
did another just now. replaced the faulty replacement plastic wheel. i'd find the write up and use the modified closet roller. there's also a $25 brass replacement out there.
i wouldn't use an old one. plastic is getting super brittle right about now. grease it up good with lithium grease and off ya go...until another one breaks.
Old Jun 19, 2012 | 10:12 AM
And another $10 fix option - https://landroverforums.com/forum/di...ight=regulator
twoxred
Oct 4, 2021 07:07 AM
RedAustinIX
Aug 10, 2020 11:43 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
