Window Regulator Removal?
Old Aug 7, 2013 | 06:36 PM
keoni004's Avatar
Question Window Regulator Removal?
I hate to post this, but I'm at a loss. Following the RAVE, I'm stuck at step 8. I'm unable to slide the upper plastic rollers out of its channel (pinched on the ends), and the three brass screws holding the channel onto the door are tight. It looks like just the pivot mechanism comes out in the diagram, but I'm not sure.
Do I need to loosen those three screws that the channel slides into? Is there a trick to getting the rollers out of the channel? As it is, in attempting to remove it, the rear window support arm fell out of the channel as the plastic roller there broke.
The two first regulator repair link in the tech section skips removal, and the second has a bunch of dead photos. Thanks.
Old Aug 7, 2013 | 08:16 PM
CUpgt's Avatar
Bend the rails straight with a screw driver and slide the roller out.
Old Aug 7, 2013 | 08:19 PM
keoni004's Avatar
Thanks again, cup. That was my initial "MacGyver" reaction...but rarely are those correct.
Old Aug 7, 2013 | 08:46 PM
CUpgt's Avatar
Just bend them back when your done. They bend pretty easy.
Old Aug 7, 2013 | 09:08 PM
TOM R's Avatar
easier to undo the 2 bolts and remove it from the door with the regulator instead of chancing breaking the bushing
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
Robover01
Dec 27, 2009 10:31 PM
