Window Stuck Down
Window Stuck Down
So when i bought my Rover I was told the drivers side rear window didn't work. Well now that it has warmed up some and I completely forgot about it I decided to roll down all the windows.
Ooops,
So the rear drivers side window went down about halfway and now won't go up. It doesn't seem to make any noises or anything, I haven't had a real chance to check it out, but I wondered if this is a common problem, and if so what is the fix?
Help is appreciated!
Ooops,
My money is on one of the "rollers" broken. They are cheap plastic and a common issue. It takes all of about 3 minutes to remove the door panel and take a peek. The pass one on my white one just did the same thing. There are some work around fixes on the board using spare parts from a hardware screen door kit etc. I think someone even sells stainless steel replacements. You can get the window back up for now by removing the door panel and using a screwdriver, get the window track to start it's way back up. Then, disconnect the window switch till you get it fixed.
All the rest of the windows work fine, this window goes down but not up. I will have to take a look at it.
The motor makes no noise when i push the buttons on either the door or the center console, so that's why i was wondering if it was something else? It seems like it would at least try to roll up the window.
Yup. it's in your passenger front footwell, its the one with the two harnesses coming out of it, the box in the middle you cna actually get to it by flipping your glove box all the way down. it's right behind it.
the bottom harness of the two with the white wire and the purple wire coming out of the top of the harness left to right respectively (pardon my color interpretation im color blind) it has a larger gauge green wire going out of one and into the other. this green wire jumps the solder point that could go bad in your window ecu
Wedge a paper clip in there good, you might hear a click. See if that helps you at all
