Windshield wiper problems
Old Jan 24, 2014 | 01:11 PM
Nay_Sayer's Avatar
Default Windshield wiper problems
I have a '98 LR Disco. The fuse keeps popping on the windshield wipers. Any ideas on how to fix/diagnose the problem?
Thanks
Old Jan 24, 2014 | 09:22 PM
ihscouts's Avatar
Google "Rave", it's the service manual.
Download it.
Then read it like it's a Fruit Loops box.
Sounds tough, I know.
Once you get to the guts post up what you find.
That's when the real fun starts.
Good luck.
That's my idea and I'm sticking to it......
Old Jan 24, 2014 | 10:23 PM
landlover_1's Avatar
Download it.
Good luck.
Hijacking this thread: I heard some shocking news on the telly last night. Fruit loops are all the same flavor! Couldn't believe it. It's just the color that is different. And here I thought I was picking out the lime ones because they're my favorite.. If you didn't already hear it last night here's the article:
Healthiest Cereals: Fruit Loops, Fruity Pebbles All One Flavor | TIME.com
Old Jan 24, 2014 | 11:28 PM
ihscouts's Avatar
Sweet.
Old Jan 30, 2014 | 08:08 PM
Nay_Sayer's Avatar
Download it.
Good luck.
Ok, I downloaded the Rave manual and looked at the windshield wiper wiring diagram. It all looked like Greek to me. Can anyone help me make sense of it all?
Thanks.
Old Jan 31, 2014 | 03:59 AM
95RRCLWB's Avatar
Are the wipers working at all or trying to work?
Maybe the motor/linkages are stuck, causing the fuse to blow due to current overload?
Old Jan 31, 2014 | 07:13 AM
ihscouts's Avatar
Right, work on the mechanical first then go to electrical. Why you'd start with the electrical diagrams in the Rave is putting the cart before the horse. Rave ETM is laid out logically, go through the introduction first.........
Old Jan 31, 2014 | 08:48 AM
Soccer Dad's Avatar
Default yep
I second 95RRCLWB opinion.
I'm afraid you need to disconnect the linkage at the motor and test the movement of the wipers for binding. this is the easy part.
Next operate the wiper motor (still disconnected) and see if the fuse blows. there is no need to get a new/used/rebuilt wiper motor. Just open it and clean the crap out, lube with the new type of antiseize containing teflon (its a white paste), check the brushes and polish the contacts with fine emery cloth. Clean the slip contact (it brings the wipers back to park when you turn them off) and lube the copper strip with battery contact grease.
Next, and this is important, make sure that the ground wire AND where it connects both at the motor and the car are good. Any poor connection here and the wipers will operate lazily.
That's all there is to it.
There is also an alternative. You could operate the wipers in the Series 1 fashion: tie a string from one wiper to the other going from the inside of the car and have the passenger pull on the string one way and then the other.
On second thought, she might blow her fuse and you will have to rebuild your marriage!
SD
flygirl92
Feb 2, 2015 09:28 PM
McGuido2008
Nov 12, 2007 12:22 AM
SpeedAgent
Oct 10, 2007 09:28 AM
Dublz
Sep 14, 2007 12:36 PM
Oldracer
Dec 25, 2006 04:46 PM
